Toposolid Revit 2024
4 ANTWORTEN 4
Nachricht 1 von 5
cole.southam
1898 Aufrufe, 4 Antworten
Hello, I just began using Revit 2024- I imported a dwg as a topo solid and when attempting to rotate the project north, the topo solid surface does not rotate. I have created a building "pad" using mass void and now need to rotate the project north, to not work at an angle, what am I missing?
It gives a warning to check the position of toposolid but no way to rotate that element to match.
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: cole.southam
Why do you need to rotate project north?
Nachricht 3 von 5
cole.southam
als Antwort auf: ToanDN
The building is on an angle relative to current elevation views
Nachricht 4 von 5
90 percent of buildings modeled in revit are at some angle,  doesn't mean their project north needs to be rotated.  Keep the project north as is, model the building upright, and rotate true north instead.
Nachricht 5 von 5
f_richardHGJY7
Hello autodesk, I went to have projected area for do nomenclature solid topo
