- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Looking for some help with a rotated section...
Our stair resides in an angled enclosure, and to document the longitudinal section I've rotated the section cut so it's parallel to the enclosure walls. However, the section 'view' also rotates with the cut, instead of viewing out parallel to the ground.
Is it possible to have an angled section cut with the 'view' looking out as marked in red (parallel to the ground)? Instead of looking out perpendicular to the cut as shown in blue?
If not, are there recommended best practices for piecing together multiple views? I tried jogging the section instead, but with the height and angle it wouldn't capture the entire stair (unless maybe there's a way to split section more than once?).
Thanks everyone!
