En esta familia parametrica el texto de modelo o Model Text se ubica centrado en un sector independientemente de la longitud que este tenga ya que esta parametrizado y restringido con el plano de referencia central;
los simbolos (isotipos) encerrados dentro de las elipses rojas son estrusiones,
la consulta es la siguiente: como mover esas extrusiones conjuntamente con el Model Text parametrizado.
Agradezco de antemano el interes
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Why don't you just pull a dimension between the end of the Model Text and "isotipos" and lock it?
...Also, have you thought about using a Wingding Font Model Text in lieu of extrusion for the "isotipos"?
Hello, I'm sorry, I couldn't answer before. Yesterday I was trying to find a solution for this issue and, unfortunately, the solution proposed for the model text now only works for the "isotypes". Yes, it's weird and I must have done something wrong.
I'm reviewing it (it's turning me crazy)
I think that your proposition is the solution for this issue and also I want to see about the Wingding Font, but I ask you for a little patience so I can check it just to be sure for me and other members of the community.
I hope you agree
Indeed it is a nice solution, I was thinking that maybe was going to be more tricky, but, lucky me, it wasn't.
just keep in mind that the 4 extrusions are geometries alone and they need to make it a group to pull only one dimension
Thanks a lot, again, for your help and support
Have a nice day
