Hi all,
Im looking for a solution for angled corner mullions as shown. Not sure why this is not default corner mullion type in Revit since its quite oftenly practiced in the field.
Solved by Avaris.. Go to Solution.
Too bad they didn't include it, unfortunately corner mullions are system families, I've seen work arounds of people who are creating two halves.
But to be honest I would either:
-model it in two parts. One using the dedicated quad corner mullion to control the size of the panels. The other part an extrusion to model the structural profile.
-model it as one generic model.
https://forums.autodesk.com/t5/revit-architecture-forum/quad-corners/td-p/7839480
Thank you Marc
I guess this may be the best workaround. It seems quite dumb to not offering corner mullions with profile alterations since it so commonly practiced in the market for years.
You can use a profile shape to do this, but it seems to bug out for interior corners.
Here is the bugged out interior corner
Quad corner mullion is not working properly - I have a corner condition at 100 degrees not 90 and the walls are joined. The quad corner mullion will not recognize that the angle is not 90 and there is no way to input that information (would be a great tool!) How do I fix this?
