All elements display in Red?
I'm using Revit Lt 2019. I'm quite experienced in using Revit and usually use my own template to start a project.
However when ever I use the Generic Architectural template to begin my model and go into a 3D view, goto Detail level Course, turn on section box and pull it down to cut the walls and doors etc. All elements cut display in Red? I have looked everwhere to fix the problem all the obvious places I've looked in materials, phases, over-rides, object styles... I just can't find out why? I can go into each element and change them individually or by category however it seems like there is a setting somewhere I'm missing.
It doesn't happen when I use my own template, only the Generic Architectural template.
Please see my picture attached.
Maybe you could test it yourself?
Thanks for your Help
Dean La Fontaine
