point clouds and general revit questions
Hi, I was wondering if somebody can help me to understand point clouds and editing objects in Revit. I have a basic understanding of revit but have little or no knowledge on point clouds.
Point cloud
- How do you use Point clouds?
- Are they only used as a form of reference such as a jpeg or pdf in AutoCad or can they be used as a complete revit model?
- In terms of the data collected from a point cloud, do you have to build each object from scratch or can the point cloud data be used in some way?
- Can trees or small parts of a point cloud survey be used as a part of a complete revit model?
- Can point clouds be manipulated in a way to make them visually better in terms of image quality,highlight smaller parts of the point cloud or for renders?
General Revit questions
- Can you download and then edit trees so they represent the real trees on a plot of land?
Hope to hear from you soon.
Thanks, Stephen
cbcarch
This is a very large subject matter, which can't fully be addressed in a forum.
Do a quick google search and you will find many resources.
Take a look here:
-https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
-https://revitiq.com/point-clouds-revit/
-http://wrw.is/creating-revit-geometry-from-poin/
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
