Align Topography Lines with Sea Level, NOT with Project Level
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was looking at this forum, but it doesn't quite answer my question: https://forums.autodesk.com/t5/revit-architecture-forum/toposurface-contour-line-issues/m-p/3709130/...
I am having a similar problem but I think it's a different issue. I have the topography and building at the proper elevation. The building first floor level is set to 0' relative elevation, but I moved the project so that that elevation is really at 1087'9 3/8" above sea level. I can verify this by setting my contour label to "Survey Point" and it displays the 1087' 9 3/8". However, as you may notice, the contour line itself is being drawn AT 1087' 9 3/8", not 1087' and 1088' like it should be. Obviously the topography is drawing its 1' contours in relation to the Project Base, not relative to sea level. Any idea how to change this? It know everything is at the right place in the model itself, I just want it to draw the contours on the toposurface relative to the actual topography.
