hi dear users
i want to just Metric templates have in my revit how i can disable imperial unit templates ?
Gelöst! Gehe zur Lösung
Gelöst von Ilic.Andrej. Gehe zur Lösung
Templates are stored here:
ProgramData/Autodesk/RVT 2016 (...or 2017, 2018....) /Templates
When you re creating a new project, click on the button "browse" and navigate to DefaultMetric Template.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Are you talking about completely removing the Imperial Templates, or editing the Project Templates list?
For removing the templates completely, you can go to C:\ProgramData\Autodesk\RVT 2018\Templates, select the US Imperial Folder and delete. There might be an easier way but that will work
Here's a useful link for defining your Project Template List
thanks
but i want to my revit program default unit be in metric nor imperial > how can i do that ?
Here's how to add the Metric Templates to the List. All you need to do is select the US Imperial templates you wish to remove and click the "-" button
Options.
(Add Value).
.The template is added to the list.
The template drives anything that is "default". Start new project using metric template and then use "un" shortcut. You will see that units are metric.
Andrej Ilić
MSc Arch
