After purge the family types are missing
12 REPLIES 12
Message 1 of 13
1118 Views, 12 Replies
Hi, I have purged my file then I loaded a door family into file which I had before. However this time door family doesn't show all types. Thank you for any help.
12 REPLIES 12
Message 2 of 13
joe_keogh
Hi The family and its types that are not placed in the project are deleted when you Purge Unused.
The door types you created in the project are not saved back to the family, only the project that you created them in.
So when you load the door family, only the Family Types defined in the Family, are loaded.
You could restore a previous version of the project and restore them from there.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Message 3 of 13
in reply to: joe_keogh
No, the problem is the Family Types that defined in the Family, are not loaded. I just see the ones that I used.
Message 4 of 13
ennujozlagam
what do you mean by that? can you see them inside your project? or go to your project browser > families > door and see if your door type is there? or try to load again your door. thanks
Message 5 of 13
Thank you for response, I tried x-ref, but it didn't let me double click and fill out the attributes.
Message 6 of 13
in reply to: ennujozlagam
I loaded the family several times, but the types exists inside the family not inside project.
Message 7 of 13
ennujozlagam
are we in the same frequency? Smiley Surprised
Message 8 of 13
ennujozlagam
can you share the family so we can check. thanks
Message 9 of 13
Xrefs? Attributes? Are we talking Revit or AutoCAD here?
Message 10 of 13
Make a small change to the family such as add a line or a ref plane, and load it again. Then you go back to the family, undo the change and reload.
Message 11 of 13
Message 12 of 13
RobDraw
Sorry, the post before yours was already marked as the solution.
Rob
Message 13 of 13
johnlim2079
I encounter this problems frequently when trying to inport any family types into my project, could you help me out thanks!
Forma Design Contest
