- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi fellas!
How do I achieve this result for stair railings?
Hi fellas!
@ToanDN wrote:
Use two hand rails, one with extension, one without, then TAB on the one with extension to edit rail > edit path, then sketch the curve to connect the two handrails.
Thanks, but I only get the option to sketch in a plan view.
(In section view) Chose the rail -> Edit path -> Go to view (area plans & floor plans)
Do I need them to be separated?
Right now we've used a railing that consists of both rails
To segway in on @ToanDN 's suggestion - once you have TAB -selected the handrail, in its properties you will see options for each end.
Have you found the solution with your stair railinings?
