Adjust end of stair railings
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
How do I achieve this result for stair railings?
Use two hand rails, one with extension, one without, then TAB on the one with extension to edit rail > edit path, then sketch the curve to connect the two handrails.
Marcus.Isacsson
Thanks, but I only get the option to sketch in a plan view.
(In section view) Chose the rail -> Edit path -> Go to view (area plans & floor plans)
Do I need them to be separated?
Right now we've used a railing that consists of both rails
You need to TAB to select the handrail only, not the entire railing.
Sahay_R
To segway in on @ToanDN  's suggestion - once you have TAB -selected the handrail, in its properties you will see options for each end.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
See below:
Have you found the solution with your stair railinings?
