Hi I have created custom sheets but in the title blocks I have 3 of the same sheet including BAK file. Why has that happened. Is there something I need to switch off in the programme?.
Solved by martijn_pater. Go to Solution.
edit: hmm your title and question are confusing. thought you were looking for above. now not so sure
I read it the same way as you -- however the BAK (an AutoCAD Backup) is unrelated to Revit.
Thanks Martiyn with your previous email
In fact it seems to be generating multiples of files with DrawingA.0002, DrawingA.0003 etc not sure how to stop that.
Perhaps you can share the file (as .zip) and/or screenshots of the issue.
Hi Martijn
Attached image in my document folder.
It creates series .0001 files. There are sometimes 8 or files which I delete.
See my first reply and follow link I posted there, set the maximum backups to a lower number (minimum 1) while saving the file to reduce the backup interval if you like.
