Adding new materials to Library
tstewart
Message 1 of 8
tstewart
How to add materials to a Library so they can be used in a model?
Replies (7)
Message 2 of 8
Message 3 of 8
tstewart
It did not work for me, so I must have done something wrong. HELP?
Message 4 of 8
What didn't work for you?  What did you do?
Message 5 of 8
tstewart
Adding new materials did not work the way I tried.
Message 6 of 8
List the steps of your workflow.   I have no idea what you've done.
Message 7 of 8
tstewart
  • ANNOTATE
  • REGION
  • DRAW (RECTANGLE)
  • PROPERTIES (EDIT)
  • SELECT FOREGROUND PATTERN (MODEL)
  • CAN'T FIND .PAT, OR NEW PATTERN PHOTOS (SEE BELOW)
Message 8 of 8
No wonder you are lost. Those steps have nothing to do with adding new materials to  library. They are not even close.
Did you even bother reading the information I provided to you in your other thread?
https://forums.autodesk.com/t5/revit-architecture-forum/adding-materials-finishes-to-walls/m-p/96476...
Also:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2021/EN...
