how to show stairs in the upper level? plan region does not work
17 ANTWORTEN 17
GELÖST
Nachricht 1 von 18
yazanhijazeen
3073 Aufrufe, 17 Antworten
Hallo all,
i am trying to show 2 staircases( 1&2) from upper level using plan region, i tried view range multiple different settings, but unfortunatelly it is not working, am i missing something ?
17 ANTWORTEN 17
Nachricht 2 von 18
als Antwort auf: yazanhijazeen
What are your view range settings?
Nachricht 3 von 18
Jason.P
Have you made sure the plan region is fully around the item you want shown. If it cuts just a bit of it off, it will not show that item.
Other then that can you share a screen grab of your view range settings.
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
Nachricht 4 von 18
Make the Plan Region Boundary slightly larger.
Nachricht 5 von 18
Try a plan region that covers the entire bounding box of the stair.
Nachricht 6 von 18
yazanhijazeen
als Antwort auf: ToanDN
Hallo everyone,
so this the view range settings that i have used, ( Shortcut: EG= GR, 1.UG= B1) (Level: B1=-3,80m, GF=+-0,00 m), as you can see from the first screen shot, the staircases are separate, i have set the cut level to 3,60 m and it only shows the Landing, during research on the internet, i read that Plan Region does not work with separated staircases, is this right?
Nachricht 7 von 18
Show us your plan region settings.
Here I have a stair from Ground to first, with floor over and stair from first to second.  The plan region cut plane needs to be below first floor level.
Nachricht 8 von 18
yazanhijazeen
als Antwort auf: Anonymous
Nachricht 9 von 18
Set Oberkante to below floor level - it seems likes its at the top of the floor.  I'm not sure of the distance between floor levels, but Shnittebene must be below the floor.
Nachricht 10 von 18
yazanhijazeen
to be honest i have tried different sets and none of them helped at all, i supposing that the plan region does not work with single staircases.
Nachricht 11 von 18
Well it does work - I did it and posted my result.  Did you try what I suggested?
Nachricht 12 von 18
@ToanDN  has your solution
Nachricht 13 von 18
@yazanhijazeen:
Did you read and understand and follow what was suggested in Message #5 and #6?
Just grab the blue, arrowhead-shaped Plan Region Shape Handles pull them outward to resize the Plan Region.
Nachricht 14 von 18
Keyword: bounding box.  Your plan region must cover the entire bounding box of the stair, not shaped to the footprint of the stair itself.
Nachricht 15 von 18
XXalessio.amodioXX
I usually hate Plan region becouse then someone hides it and get me crazy with VR.
I prefer Model del starirs separatelly and link it in main model.
Nachricht 16 von 18
als Antwort auf: XXalessio.amodioXX
That makes no sense to me.  Rather ask your colleagues to hide Plan Regions using VR and not Hide in View.  It's a whole additional workstream that you adding to link in the stairs.
Nachricht 17 von 18
XXalessio.amodioXX
No.
I do it so even because I model stairs as Generic model and prepare corrisponding  views in the linked one.
It is pratically impossible to modify revit stairs in order to overocme your needs and/or match run/landings line style to Country requirements.
After 3y of BIM management this is the best solution I have found.
If you have smt better feel free to give me some tips :leicht_lächelndes_Gesicht:
Nachricht 18 von 18
yazanhijazeen
Hallo everyone,
@Anonymous @barthbradley @Anonymous
it finally worked, i went again over the comments and all i needed is to extend the borders just 2 cm and the stair is shown. sorry for bothering and thank you guys.
