Adding a "Discipline" Parameter
Nicht anwendbar
5.535Aufrufe
8Antworten
Nachricht 1 von 9
Nicht anwendbar
I need a reminder.  We have more than the standard Disciplines on my current project.  How do I add a "Discipline" to the list of Disciplines listed as choices?  I need to add some like Kitchen, Security, Signage and so on.  I don't want them as sub categories.
Thank You
Nardo
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (1)
5.536Aufrufe
8Antworten
Antworten (8)
Nachricht 2 von 9
if it is for Browser organization then create a different parameter and assign it to Sheets and Views categories.  If it to delineate work responsibility then use worksets.
Nachricht 3 von 9
Nicht anwendbar
When I am putting in the Parameter it shows as a independent parameter.  It isn't going in as a Discipline.  It doesn't show up in the Disciplines list.  How can I get the new parameters to show up in the existing Disciplines?
Nardo
Nachricht 4 von 9
Pardon me, but I'm a little confused by your intermingling of the terms: "Parameters" and "Disciplines". But, I think you may be wanting to add a project parameter of the text type to your views. Right?
Nachricht 5 von 9
Akzeptierte Lösung
Nardo
The Discipline parameter is hard-coded and cannot be changed.  The new parameter should just be a Text instance parameter assigned to Views and Sheets.
Nachricht 6 von 9
Nicht anwendbar
I was trying to add Disciplines to this list.  But I guess this list is Hard Coded.  So that's out.  See below
Nachricht 7 von 9
So, I guess I was right. Right?
Nachricht 8 von 9
Yes, I get that. It sounded as though you were even aware of that already, and was trying to remember out how to add a "Discipline" named text parameter field to your view properties. This would easily be accomplished by adding it through Project Parameters, as Toan and I suggested.  Each view then could be assigned a unique discipline of your choosing. You'd just enter that name in that project parameter field that you created and assigned to the View's properties.
Nachricht 9 von 9
You left the question for me or OP?  Either way, yes.
