Add depression to the Floor
4 REPLIES 4
payam.rad
371 Views, 4 Replies
Having options to add points and split lines to the slab and adjust the elevation to create a slope is a great tool. It would be great if we can also have the option to create a simple "depression" onto the same floor. this comes in extremely handy for concrete floors.
4 REPLIES 4
RDAOU
in reply to: payam.rad
@payam.rad
As long as you can do it using the basic opening tools elements, the option is there.
Alternatively:
  1. Use a void (in place or a loadable family)
  2. Or use two floor elements and join them
If you still feel your idea could be popular to voted and Autodesk to add due to public demand, go ahead and post it on the Revit Ideas Forum
You can place a shaft to create the floor depression.
payam.rad
Sorry Guys, I meant to post this in to the Revit Ideas. I understand and I am aware of all these "workarounds". there should be an easier way to do this!
I repost this onto Revit Ideas. it would be great if you vote it up. See the idea here:
https://forums.autodesk.com/t5/revit-ideas/add-depression-to-the-floor/idi-p/11089491
RDAOU
@payam.rad
Cool but these are not workarounds these are several ways to do a depression some of which have been used since Revit 6.0
Nonetheless, let us assume you are right 🙂 ... in comparison to simply using an opening element or a void, how much easier would a depression be according to your idea?
