Add a wall layer with angled ending
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
We need to add a wall layer (red line, bricks). The layer shouldn't follow the whole wall and also needs an angled ending (red arrow).
What's the easiest way to accomplish this? Would neat to have together with the rest of the wall.
Add the layer and void, or is possible in another way?
dzanta
If you only need the brick layer added for that room, then I would split the wall, duplicate the one you have, add a brick layer and continue.  It should clean up automatically
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Avaris.
Just create a wall type with only a brick layer, place it over the length where you need it and join it to the longer wall. That way doors and windows will penetrate both walls. If the material at the angled wall is the same it will join neatly. Otherwise place an extruded in-place void to cut the bricklayer.
Illustration of what every body has said.
Sounds like you need another wall.
Regarding angle: that's just a join condition.
