add 2 Photometric Web Files
s3687147
Message 1 of 22
s3687147
Hi i was just wondering if is possible to add 2 photometric files, considering that there is 2 lights in opposite directions.
Cheers,
Replies (21)
Message 2 of 22
Try Nesting  it as a Shared Family
Message 3 of 22
s3687147
thanks for the tip but ,I tried and it doesn't work. not sure if I'm doing it wrong or if it doesn't work.
I have attached the file, hopefully it helps 🙂
Message 4 of 22
Nest a Shared Light Family  into another Light Family (the "Host")  and then load and place an instance of the "Host" Family in the Project.  Now TAB-Select on the "Host" Family to select the Nested Light Fixture, and once it's selected you will be able to edit the Photometrics of the Nested Light Fixture (and any other of its Properties)  independently of the Host Light Fixture.  Two Light Fixtures in one.  That is what you are after; right?
Message 5 of 22
- Create a light family (A), set it to Shared, add the IES
- Create another light family (B), load (A) in, place it twice (or mirror, copy, whatever works)
- Load (B) in project
Message 6 of 22
BTW: it's not necessary that the Nested Shared Light Fixture Family have anything more in it than the light source.
Message 7 of 22
s3687147
YESSS!
Thanks for helping 🙂 🙂
Message 8 of 22
WTF? @ToanDN suggested exactly what I suggested TWICE -- and he get's thanked?  What about me?
Message 9 of 22
s3687147
thanks to you to 🙂
Message 10 of 22
@s3687147 wrote:
thanks to you to 🙂
Don't mention it.  😉
Solution credit too?
Message 11 of 22
s3687147
when importing the photometric file it positions itself into a weird angle and also i am unable to pin the imported photometric file to the light (family).
Message 12 of 22
Bummer.
Message 13 of 22
You want it aimed upwards?  Change the Tilt Angle.
Message 14 of 22
s3687147
Amazing,
Thanks so much for your help 🙂
Message 15 of 22
s3687147
Sorry i have 1 and hopefully last question.
Is there  away of combining the photometric files as 1 ? the reason I am asking is because I need to have right details for the calculationsCapture.JPG
Message 16 of 22
Sure. Don't Share the Nested Light Family. Just associate its Photometric Parameters to the Host Photometric Parameters. You'll need a second Tilt Angle in the Host to control the angle of the Nested Family, if that's important.  Or just tilt it and leave its Tilt Angle unassociated.
Message 17 of 22
s3687147
problem solved. thank you 🙂
Message 18 of 22
shellysC63L4
Observer
Observer
Hi. Is there a way to link the photometric file of the nested lighting family, to a second Photometric link in the Host family? In another word, is it possible to have two "Photometric Web File" parameter which each can be linked to a different Photometric file?
Message 19 of 22
Not sure I understand. You can Nest Shared Families into a Parent Family and independently modify the Photometrics of each Nested Shared Family in the Project.  That sounds like what you are after.
Message 20 of 22
shellysC63L4
Observer
Observer
Thank you for your answer, but no. I want to link the "Photometric Web File" of both nested families (A & B) to a "Photometric Web File A" and "Photometric Web File B" parameter in the host family. So, I will be able to make a Family Catalogue in which I put all the different configurations for different Photometric files. The thing is there is only one "Photometric Web File" parameter in a BIM file parameter window which is "Built-in" parameter. Is there a way that I can make two of them? I hope I could explain it well!
