- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I found a good tutorial here for how to make an adaptive arch and even provides a download of the final product but since it is 2020 format and I onluy have 2019, I decided to give the tutorial a go.
I am up to 7:20 in the tutorial where I have to add a formula to make H1 parameter equal the HR parameter.
When I add the formula in as per the video, I get an error:
"A reporting parameter can be used in a formula only if it's dimension references are all to host elements in the family"
Considering my family type parameters look identical to the video, I don't understand why this error appears (almost the same apart from the default elevation constraint but I'm not sure where that came from...
This is from the tutorial:
and this is mine:
Does anyone have any ideas why this is happening? From what I can see, the reporting parameter (HR) should be reporting therefore should be correct.
