Adaptptive Arch Family Problems
2 ANTWORTEN 2
Nachricht 1 von 3
BugFinder
408 Aufrufe, 2 Antworten
I found a good tutorial here for how to make an adaptive arch and even provides a download of the final product but since it is 2020 format and I onluy have 2019, I decided to give the tutorial a go.
I am up to 7:20 in the tutorial where I have to add a formulato make H1 parameter equal the HR parameter.
When I add the formula in as per the video, I get an error:
"A reporting parameter can be used in a formula only if it's dimension references are all to host elements in the family"
Considering my family type parameters look identical to the video, I don't understand why this error appears (almost the same apart from the default elevation constraint but I'm not sure where that came from...
This is from the tutorial:
and this is mine:
Does anyone have any ideas why this is happening.  From what I can see, the reporting parameter (HR) should be reporting therefore should be correct.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: BugFinder
There's no host in this family, so you can't use a Reporting Parameter in this fashion (e.g. in a Formula).  I'm not even sure why the tutorial is instructing you to create Reporting Parameter/Dimension.  Seems purposeless.  Are you sure you are following the right tutorial?
Nachricht 3 von 3
bin
Sorry about my silent video, must be very hard to follow.
You just need to make those 3 points adaptive.
:leicht_lächelndes_Gesicht:
