Re: Generic Family
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
Pinky_Job-VEC
566 Aufrufe, 5 Antworten
Re: Generic Family
Hi All,
I created a generic family for no fly zone. But for some reason, I can't control or change the depth when I load it into main project. If anyone has any idea how to solve this, please do let me asap. I have a big deadline tomorrow and it would help a lot. I notice the depth set to 1'-0" when I extruded. IS that the reason I cannot change the depth. I am attaching the family here.
Thanks!
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Pinky_Job-VEC
attached
Nachricht 3 von 6
Pinky_Job-VEC
als Antwort auf: barthbradley
@barthbradley: Thank yo fr your quick response. I cannot open this file since it's in 2020. I am using 2019.
do u think u can save in 2019 version. also can you let me know what you did differently.
Nachricht 4 von 6
syman2000
Here you go
Nachricht 5 von 6
Here is 2019 Family. The Family can now be sized (e.g. shaped) dynamically in the Project Environment via dragging Shape Handles, and/or by entering Dimension Values in the Parameter Fields.  Note that "t9" has been added and "t.length" is now a Reporting Parameter for overall length.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Nachricht 6 von 6
Pinky_Job-VEC
I have 1 more isssue with this family in regards to the graphics. I reduced the transparency of this family, but when I loaded it into the main project, It is solid and not transparent.
