Hi all,
I am currently learning Revit and using the 2020 student version. I am trying to find the AutoDesk seek function. Is that not available on the student version?
Thank you
Solved by eng.mostafa2414. Go to Solution.
It's not part of Revit. Refer to this link to find seek.
Autodesk seek has became BIM object
You will find a plugin at the site that you can add it to Revit or just download from the site directly.
Mostafa Elashmawy
No one here has your information.
