A serious error has occurred. It is strongly recommended that you use Save As to save your work in a new file before continuing.
dino9JUD7
Observer Observer
dino9JUD7
Observer
Observer
Hello, can somebody help me with this.
I read previous solutions about this but nothing helps.
I have updated my revit to the last version but I still have the same error while copy/mirror/array elements.
It's not file-related, because my colleague can open it and copy without problem error issues. It's my revit 2023-related.. I have the same problem with copy/mirror in other revit-project files to.
Let's see what it says under "Expand>>".
Follow these steps to resolve the issue:
  1. Close all Revit Sessions on the affected machine.
  2. Rename the following file (instead of removing the folders listed in the solution below): C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\Autodesk Revit %VERSION%\DDGraph
  3. Restart Revit.
Alternatively:
Copy and paste a healthy DDGraph file from another machine, where the issue is not reproducible.
If the above steps do not help, clear the content of the following folders:
  • C:\Users\%USERNAME%\AppData\Roaming\Autodesk\Revit\Autodesk Revit %VERSION%
  • C:\Users\%USERNAME%\AppData\Local\Autodesk\Revit\Autodesk Revit %VERSION%
%USERNAME% should be your windows login name.
%VERSION% should be your Revit version.
PrathapSekar
Hi @dino9JUD7 ,
Something helped?
I had a similar issue with the earlier version and did the following,
  • updated the Revit to latest version (URs & Hotfixes).
  • Removed all add-ins and reinstalled them.
  • in some cases Revit had to be reinstalled.
Thanks.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
