A few how-to's
- Mute
- Permalink
- Report
I've a couple of issues which I'm hoping someone can help with:
Firstly I have a question regarding a dormer cutout. "conveniently" there is a wall right at the point the dormer roof meets the roof and the resulting cutout not only cuts the roof but the wall under it too...
The red outline shows what I describe. Looking at the dormer profile:
I believe I want to select the red line on the left hand side of the wall but if I try and choose this, I get the error message as above. If I select the only line it will allow me to select, the pink line on the right hand side of the wall, then I get the cutout in the wall as well.
What do I do here?
Secondly, what is the correct procedure for finishing off the outer wall of this chimney:
As far as i'm aware I cannot choose a sloping wall to start from and then set the top constraint to the top of the chimney????
Once I have the side of the chimney, what is the correct way to cap off and add chimney pots? Are they available as a family or do you have to create these yourself?
Thirdly, are there any issues with the walls at the end of this building:
Why does this occur? Is is due to the way i've built it or is it just a rendering issue? It seems to happen quite a lot in various walls so I'm curious whether I need to be concerned (other than they look awful!!)
Thanks in advance.
