70s Window Sizes - Never seen this before
DOUG45WL6
DOUG45WL6
Anyone know how these numbers define the window size? Old set of plans from the 70s.
DOUG45WL6
syman2000
The number could be
349 - 3' x 4'-9"
318 - 3' x 1'-8"
alan_eu
It´s the "Type Mark" window number.
Probably you will find a table showing the dimensions for each of these windows.
349,  318...
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
DOUG45WL6
Could be, although I don't have that sheet. I will measure and see if anything makes sense but at least I'm not crazy. Possibly. Thanks.
RobDraw
The numbers are for identification and probably correspond to the dimensions but they could also have some other meaning. There is no doubt that they are type tags and the same numbers are used in the schedule to identify them.
Rob
