3D view will not crop
mason
Message 1 of 9
mason
I can't get this 3D view on a sheet to crop. You can see the crop region around the house. I'm not sure what's going on - any ideas? The view is locked.
Replies (8)
Message 2 of 9
Check Crop View in View Properties.
Message 3 of 9
Mike.FORM
I suspect you only have the "Crop Region Visible" checked in Properties. You need to check "Crop View" also.
Message 4 of 9
A view can be uncropped and still shows a crop region.  Make sure Crop View box is also ticked.
Message 5 of 9
mason
Crop view is also checked. It is grayed out (I'm assuming because the view is locked).
Message 6 of 9
mason
I'm not sure what has happened to this view! I just created a new one and started fresh.
Message 7 of 9
It's locked because the View is Locked.
Message 8 of 9
ennujozlagam
check if you have view template assigned, set to none?
Message 9 of 9
amy
Make sure the scope box is set to none, then you should have been able to adjust the crop region.
