Export Revit To AutoCad
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
jorgedacunha60
358 Aufrufe, 3 Antworten
Hello All,
I have export Revit LT 2024 to AutoCad, the problem is when my client open the autocad, all files are colorful instead black/white. This is my first time exporting from Revit LT 2024 to Autocad. Could someone help to solve this problem. Thanks in advance
3 ANTWORTEN 3
Nachricht 2 von 4
blank...
als Antwort auf: jorgedacunha60
Nachricht 3 von 4
HVAC-Novice
For the few occasions someone needs dwg, I just give them my Revit model and let them extract what they need. Last time was 2 years ago.....
It is my understanding you kind of have to export each view or sheet individually. And that still may miss something the other person needs. I imagine it is a pain to do that for any reasonably sized project.
Probably better to know first what the purpose of dwg is so you can target what you need to export.
Revit version: R2025.4
Nachricht 4 von 4
The colors are defined in the CAD Export Options.  But the real question is why your client needs a black and white drawings?  Even CAD drawings created in AutoCAD are usually with colors for clarity.  They can be printed out to black and white regardless of the actually colors in the drawings.
