Hello
I would like to create a 'glazing schedule' as my current work doesnt use the window option for glazing. (They have a curtain panel option for glazed panels instead). I have created the schedule and selected the fields I want to include. Similar to a door, I have 'tagged' the curtain panels and named them W01 and W02 and so on. In this case, they are 2700mm high x 600 wide side lights.
In my new schedule however, there option for curtain panels for the 'Mark' field is not linking. How do I get the tag to show on the shcedule? The window 'tag' is the same type of tag that has been applied to the door (screenshots attached)
thanks!
Tessa
The schedule must be a schedule of curtain panels, not another category. The identification of the panels can be either by instance using the Mark property, or by type, using the Type Mark property. If you pass either property or field to the schedule it should work. Maybe you are doing something different?
I notice that your Schedule Phase Filter is set to Show Previous + New. Change it to Show Complete. Make sure the Phase is set to a Phase that the Curtain Panels are in. Currently it's set to STAGE 1.
Actually, I take that back. Go to Sorting and Grouping Tab and check Itemize all Instances.
Sounds like you have more than 2 panels and your schedule only shows 2? Are you grouping them in the schedule by a parameter? Go to Sorting tab and tick Itemize all instances.
thanks for your reply. revit has 3 schedule catergories for curtain panels: curtain panel, curtain system and curtain wall mullion. i've made schedules for each and included Mark and Type Mark in the fields and none of them show the tag. any other suggestions?
I changed to 'complete' but this didnt change anything. Our Stage 1 phase is anything new thats been added to the project and the 2 glazing panels in question are new so in theory the schedules should show the tag number. any other suggestions?
