- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In my quest to eliminate all warnings I find overlapping rooms/spaces to be an issue. Often caused by some incomplete wall or incomplete room/space separator. The warnings tell me which rooms/spaces are impacted.
My usual way to find and resolve the issue is to use plan and section views (with room/space interior fill enabled) and look at suspicious areas.
but what would be nice is a 3D view I can navigate through and find those. Unfortunately showing rooms and spaces this isn't an option in Revit. A while ago I found the attached Dynamo script that shows me 3D rooms/spaces. The problem is, I can't really rotate the " model" in dynamo and once I zoom far into the building, I don't see the rooms/spaces anymore. So this won't really help me. also would be nice if every room/space had a different color to find the overlaps better
Is there a better way than my original method (floor/section views) or am I doing the 3D thing wrong?
My original way works, but I really would like to have some improvement.
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
