3D View Is White or Not Visible
13 REPLIES 13
Message 1 of 14
4363 Views, 13 Replies
Eventually my views turn white or blank.
Does anyone have any recommended troubleshooting steps to combat this?
My goal is to restore an image back into my view and prevent this entirely.
13 REPLIES 13
Message 2 of 14
I don't understand the issue. Can you elaborate?
Message 3 of 14
in reply to: barthbradley
Thanks for checking in.
The views I have eventually do not show any visible material. Even the ViewCube is missing.
I think this is more of an application issue and not a how to use Revit issue.
Have you seen this issue before or a similar issue?
Message 4 of 14
joe_keogh
Hi @Anonymous
Are there any modeled elements in the file you shared the screen shots of?
What should we be seeing other than the View Cube.
Joe Keogh
Director | Design Technology + Innovation
www.viewlistic.com.au
Message 5 of 14
Those big blank areas are the "Drawing Windows".  That's the environment you model in.
Message 6 of 14
bin
It’s probably hardware issue. Try to turn off 3D Graphic card setting under Option and restart Revit. Or even restart your computer. You can also ask someone to open your file to see whether it’s the file or your Revit(computer).
Message 7 of 14
in reply to: joe_keogh
Yes, there are modeled elements in this view that we should be seeing.
On another computer, I am able to view the material.
Message 8 of 14
joe_keogh
Is that Building linked into the project, or is it modelled in the project?
Joe Keogh
Message 9 of 14
Avaris.
What if you press ZA? It is the zoom all function and restores your view most of the time.
Message 10 of 14
Possibly a few components located away from your model? Then when you zoom extents it only shows you white and it’s extending the whole screen?
Message 11 of 14
Anybody mention Worksets yet?
Message 12 of 14
bin
The answer is ….
Message 13 of 14
in reply to: bin
I made a batch file and it resolved the problem.
Based off of this guide here: https://knowledge.autodesk.com/support/revit-products/getting-started/caas/simplecontent/content/aut...
FYI - Replace %USER% with your Windows user profile name.
Thanks for everyone's help.
REM SET UP
MKDIR C:\TEMP
REM CLOSE REVIT
TASKKILL /FI "IMAGENAME EQ REVIT.EXE" /F
TASKKILL /FI "IMAGENAME EQ REVITWORKER.EXE" /F
TASKKILL /FI "IMAGENAME EQ REVITACCELERATOR.EXE" /F
REM RENAME USER'S REVIT UI FOLDER
REN "C:\USERS\%USER%\APPDATA\ROAMING\AUTODESK\REVIT\AUTODESK REVIT 2018" "Autodesk Revit 2018-OLD"
REM BACK UP REGISTRY
REG EXPORT "HKEY_CURRENT_USER\SOFTWARE\AUTODESK\REVIT\AUTODESK REVIT 2018" C:\TEMP\%USER%_REVIT_2018_UI.REG /Y
REM DELETE CORRUTPED UI
REG DELETE "HKEY_CURRENT_USER\SOFTWARE\AUTODESK\REVIT\AUTODESK REVIT 2018" /F
EXIT
Message 14 of 14
@Anonymous: something doesn't compute here. Are you saying that this resolved your issue?  WTHuh?
