3D view is not wide
3D view is not wide
truongth
3D view is not wide
truongth
Hello there, I am doing project and I come to an issue where my 3D view only shows half of the house. I try to SHIFT + LEFT MOUSE but still the view is not wide and does not show entire house. Thank you for helping !
Accepted solutions (3)
blank...
You have "Crop view" turned on.
s.iwasakiSYTFM
Check the Section Box in the 3D view.
The “Section Box” can be found in the 3D View Properties.
If the Section Box does not appear, please check here.
Video: Use a Section Box
Please click the Accept Solution button if my reply answers your question.
こちらの投稿は役に立ちましたか?良ければ「いいね」お願い致します!
こちらの投稿があなたの問題解決に寄与した場合、「解決策として承認」ボタンのクリックへのご協力をお願い致します。
Satoshi Iwasaki
ONESTRUCTION Inc.
ennujozlagam
you need to untick all of these?
if still not solve the issue try to install update from autodesk and intall latest graphics card driver and see if helps.
jay_colc
It looks more like a graphical issue, along with the Crop View Suggestion, can you close the 3D View Delete it from the Project Browser (right Click > Delete) and Recreate a NEW 3D View - View Tab > Create Panel > 3D View - does it act the same?
Jay Colcombe
Autodesk Certified Instructor
vitorbortoncello
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
truongth
thank you
