Polylines are not generating for some rooms when I try to export them into a DXF or DWG file.
1 ANTWORT 1
Nachricht 1 von 2
Shrikant.PardeshiLFR8V
125 Aufrufe, 1 Antwort
Hello all,
I am facing this weird problem when I try to export the DXF or DWG file for my current  project.
To export all Room boundaries as polyline I have checked the "Export rooms and areas as polylines" options from export setting. It's working fine for most of the Rooms but 1 or 2 Rooms are not generating polylines. I am not able to figure out the difference between 'Good rooms-which are generating polylines' and 'Bad rooms-which are not generating polylines'.
Do anyone know more about this?
1 ANTWORT 1
Nachricht 2 von 2
Ensure that the room boundaries are fully enclosed. Even small gaps between walls or other boundary elements can prevent the room from being recognized correctly during the export process.As a temporary workaround, you could manually trace the boundaries of the problematic rooms using detail lines and export those, although this might be less efficient.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
