2d section drawing 3d perspective
2 REPLIES 2
3760 Views, 2 Replies
i would like to achieve a drawings like this. but camera view with section box will have close to, but not exactly straight 2d section cut line, distorted due to the field of view. on the other hands, 3d view (parallel projection) oriented view to section will not have a vanish point in the middle.
can anyone give me an insight on how to get this using a revit model?
Thanks in advance.
2 REPLIES 2
constantin.stroescu
  1. It can be done directly from Perspective from point of view using Section Box. It is import how the camera is placed: It has to be perpendicular to the back wall and if you want a symetrical view then place it just in the center of the object....
  2. Another method could be using first a 3d View orientated to a Section View and then turned into a 3d Perspective View.
Anyway, I find method 1 a quicker one.....
Constantin Stroescu
in reply to: constantin.stroescu
Thank you very much Mr. Constantin. The video is very helpful!
Forma Design Contest
Technology Administrators
