2017 revit live add-in not appearing on ribbon
leigh
Message 1 of 8
leigh
hi ,
i recently installed autodesk live.
it appears on my desktop. when i open revit, the add-in doesnt appear on the ribbon alongside my Bluebeam & 'formit; add-ins. i think its something to do with the location of the files.
can anyone let me know how to get the autodesk live add-in into my add-in ribbon?
thanks in advance
Replies (7)
Message 2 of 8
JvanReij
Hello @leigh,
If I understand you correctly the Revit 'Go Live' button is not showing up?
You may want to try and update your Revit Live add-in.
If this does not solve your issue you may want to have a look at a case running about it (link). The workaround at this moment until it is solved:
  1. Remove render appearance paths
  2. Remove all the custom texture files in shared material folder
  3. Restart Revit and check if the add-in starts
  4. Add back in texture files a small amount at a time and check usability
In case this is not what you meant, please say so. Then I can help you with this issue further.
However, if my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Message 3 of 8
Viveka_CD
Hi @leighl
Welcome to the Autodesk community! Congratulations on installing Revit LIVE
I encourage you to take a look the LIVE release notes for more information
I suggest that you update your add-in from you Autodesk Desktop App, see image below for reference
Autodesk desktop app - update revit live.JPGAutodesk desktop app - update revit live.JPG
Please check if you are able to see if you addin in your C:drive at the following location.
C:\ProgramData\Autodesk\Revit\Addins\2017
You should be able to see the 'Go live' button under Add-ins
TIP: Please NOTE that 'Dynamo' is under the manage tab, not add'ins tab, since Revit team wanted to add Dynamo as a feature more than an add-in.
Please mark this response as "Accept as Solution" if it answers your question, to help other users looking for a similar solution. Kudos gladly accepted.
Message 4 of 8
leigh
Thanks for your help
Where should I find the shared material folder?
Thank you
A: 170 Abbott Street, Newstead, Launceston, TAS. 7250
M: 0411 294 351
E :
[email protected]
W :www.adamsbuildingdesign.com.au
P Please consider the environment before printing this
Message 5 of 8
JvanReij
You can find the material folder at:
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures
I hope the steps work, if not please say so and we can help you further.
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Message 6 of 8
leigh
If I follow the steps
All I find is this
There is no texture file hi any of these
M: 0411 294 351
E :
[email protected]
Message 7 of 8
JvanReij
That's strange, in my understanding, you should see something like the picture below (@Viveka_CD, please correct me if I'm wrong).
Did you try and update Revit Live?
At the former installation, did you get any messages that a part couldn't be installed?
Best regards,
Josha van Reij
Arcadis NV
BIM manager
Message 8 of 8
nathan.campbellCCD22
I have had the same issue, which files do I need to delete?
