Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Make sure all the service packs have been applied...There have been a couple of them.
Hi ToanDN, sorry for taking so long..I was in sick leave.. this is the Revit 2017 file which I did in my home computer which is a Windows Ultimate 10. Then I tried to open this file at work using Revit LT 2017 but I couldn't. I get the message:"Project Cannot be opened in Revit LT because it was last saved in a version of Revit prior to 8.1"
The computer at work is also Windows 10 but pro.
Hi @Anonymous
SOLUTION:
You can always download a demo of the full version, and update the files, so it can be read in the current version of Revit LT.Use the demo to convert the old files / save on the trial version then reopen with Revit LT. Try and let me know if this works.
Your file works fine for now. Update the service packs - link HERE
Please select"Accept as Solution" if it answers your question and benefit other users looking for similar solutions. Kudos gladly accepted.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
@Viveka_CD wrote:
Hi @Anonymous
- The error message for files created by a later version format is not related to this error code ("file cannot be opened in Revit LT because it was last saved in a version of Revit prior to 8.1.")...This error code appears to be a Revit LT issue. It happens to appear when one tries to open (on LT) an older file format created by a full Revit version.
- Programming functionality has changed with 8.X LT just could not read the code from 8.1 and prior because few elements of core program was reorganized.
SOLUTION:
Did you totally miss the part that the OP says they have 2017 for both versions of Revit? It's a update/service pack issue. The solution is to make sure both versions have the same service packs installed.
@Anonymous
The service pack upgrade link is provided in the previous post as well.
Viveka CD
