Using AVF on ductwork - Coordinates issue?
phague
phague
I am currently trying to create an add-in that will allow me to perform a calculation on various points on a duct face.
For now, the user is selecting the face, but in the future, I plan to process the top face of each duct in the view.
I am following along with the RvtFader example project.
A reference to my face is passed into the SpatialFieldManager, exactly like in the RvtFader example.
The UpdateSpatialFieldPrimiate method runs without error, and my duct is shaded with a single solid color.
I believe my issue is that I am feeding the FieldDomainPointsByUV with UV points that are in the global coordinate system instead of the local coordinates system to the face. I suspect because create a BoundingBoxUV of my face, and supplying the bb.Min and bb.Max, along with 0, 10 as FieldValues, I get a correctly shaded (using a gradient) duct.
Is there a way to convert WCS XYZ points to local UV points?
I assume I don't care about the z coordinate...
What am I missing here?
Here is my relevant code:
      static SpatialFieldManager SetUpAvfSfm(View view, Reference faceReference, Face face)
            if (view.AnalysisDisplayStyleId == ElementId.InvalidElementId)
                SetAvfDisplayStyle(view);
            SpatialFieldManager _sfm = SpatialFieldManager.GetSpatialFieldManager(view);
            if (null == _sfm)
                _sfm = SpatialFieldManager.CreateSpatialFieldManager(view, 1);
            else if (0 < _sfp_index)
                _sfm.RemoveSpatialFieldPrimitive(_sfp_index);
            _sfp_index = _sfm.AddSpatialFieldPrimitive(faceReference);
            if (_schemaId != -1)
                List<int> results = _sfm.GetRegisteredResults().ToList();
                foreach (int idx in results)
                if (!results.Contains(_schemaId))
                    _schemaId = -1;
            if (_schemaId == -1)
                AnalysisResultSchema schema = new AnalysisResultSchema("Test", "Test Description");
                //List<string> unitNames = new List<string>(new string[1] { "Score" });
                //List<double> unitFactors = new List<double>(new double[1] { 1.0 });
                //schema.SetUnits(unitNames, unitFactors);
                if (_sfm.IsResultSchemaNameUnique("Test", -1))
                    _schemaId = _sfm.RegisterResult(schema);
                else
                    List<int> existing = _sfm.GetRegisteredResults().ToList();
                    foreach (int idx in existing)
                        if (_sfm.GetResultSchema(idx).Name == "Test")
                            _schemaId = idx;
                            break;
            return _sfm;
 private void PaintFace(Document doc, SpatialFieldManager sfm, Element element, Face face, Dictionary<XYZ, double> ductMap)
            //BoundingBoxUV bb = face.GetBoundingBox();
            //UV min = bb.Min;
            //UV max = bb.Max;
            IList<UV> uvPts = new List<UV>();
            //uvPts.Add(bb.Min); // adding these points created a successful gradient
            //uvPts.Add(bb.Max); // adding these points created a successful gradient
            IList<ValueAtPoint> uvValues = new List<ValueAtPoint>();
            //uvValues.Add(new ValueAtPoint(new List<double> { 0.0 })); // adding these values created a successful gradient
            //uvValues.Add(new ValueAtPoint(new List<double> { 10.0 })); // adding these values created a successful gradient
            List<double> vals = new List<double>(1);
            vals.Add(0);
            foreach (KeyValuePair<XYZ, double> kvp in ductMap)
                UV pt = new UV(kvp.Key.X, kvp.Key.Y);
                uvPts.Add(new UV(kvp.Key.X, kvp.Key.Y));
                vals[0] = kvp.Value;
                uvValues.Add(new ValueAtPoint(vals));
            FieldDomainPointsByUV pnts = new FieldDomainPointsByUV(uvPts);
            FieldValues fVals = new FieldValues(uvValues);
            sfm.UpdateSpatialFieldPrimitive(_sfp_index, pnts, fVals, _schemaId);
jeremy_tammik
Normally, the UV coordinates depend on the face. Simply converting the XYZ X and Y values directly to UV will not work.
To convert a XYZ point to the face UV space, you can use the Project method to project it from global 3D space onto the face 2D:
https://www.revitapidocs.com/2023/4bee3e30-74fa-3103-c2f4-d07618fbcedf.htm
phague
Jeremy,
Thank you. That was just what I needed!
