How to create a curve
ssw9UZNL
ssw9UZNL
Hi All,
I know this is very simple, but I can not work it out.
If I want to create a curve using the Revit API- how do I do this.
I have made two points, and I simply want to use these to make a curve that I can then use to make a model line.
Point_A = DB.XYZ(0,0,0)
Point_B = DB.XYZ(100,100,0)
Thankyou
ricaun
If your curve is a Line.
var line = Line.CreateBound(Point_A, Point_B);
Here the reference: https://www.revitapidocs.com/2015/7885bdf9-3007-ea60-af6b-a96ac7672c18.htm
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
