Tooltips of family parameters via API
marcelo_quevedo
marcelo_quevedo
We need to query and edit the Tooltips of family parameters through the API. As I have investigated the API documentation, the Revit API does not provide access to work with Tooltip of a family parameter; However, it is really important for us to read the Tooltips of parameters from existing families to set/edit automatic Tooltips. We would be very grateful if you could help me with some directions or workaround to achieve this task?
Thanks so much in advance!
Marcelo Quevedo
jeremytammik
Dear Marcelo,
Thank you for your query.
You can access and manipulate tooltips quite easily using the Windows API.
Kean Walmsley implemented a tooltip translation utility for AutoCAD and Inventor, and I adapted it for Revit as well:
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
RPTHOMAS108
There is certain access to family parameter tooltips via the API.
To set a tooltip you use FamilyManager.SetDescription (strangely there is no similar .GetDescription).
Description (tooltip) is a property of the ExternalDefinition class but all FamilyParameters appear to have InternalDefinitions (regardless of source) in the RevitLookup. I don't know if this is an error in the Lookup tool or the reality that FamilyParameters (even shared ones with GUIDs) don't have ExternalDefinitions.
I mention the above because unfortunately the InternalDefinition has no Description property (is this what you mean)?
marcelo_quevedo
Thank you, Jeremy and Richard, for your replies.
I could use FamilyManager.SetDescription to set the ToolTip FamilyParameter as Richard mentioned; however, as first action, I need to read the existing ToolTips that were set by the user because I need to translate them to other language. (Image explanation is attached).
I could read the Tooltips that are stored in a sharedParameter file.  Only in this case, when I read the parameter from shared parameter file, I could access to ExternalDefinition.Description. Here a sample code lines about it.
  DefinitionFile df = this.m_app.OpenSharedParameterFile();
  ExternalDefinition  ed = df.Groups.First().Definitions.First() as ExternalDefinition;
  string toolTip = ed.Description;
Nevertheless, this shared parameter file approach is not completely a good solution because users create families with some shared parameters by using their share parameter files, and I don’t have access to these shared parameter files to obtain the tooltips because as you know, shared parameter files don’t travel with Revit files.
Also, I still need to access to Tooltips that are set in the Family Parameters (not shared).
If you have some extra idea, I will appreciate a lot.
Thank you so much guys.
Marcelo.
tamas.deri
I am having the same problem, so I've created a corresponding Revit Idea, please vote!
https://forums.autodesk.com/t5/revit-ideas/revit-api-read-familyparameter-description/idi-p/10596144
