Sweep creating: How the profile is rotate?
longt61
Message 1 of 9
longt61
When create a sweep, the profile, the path must be on xOy plane. As far as I understand, the profile must be rotate to stay on the working plane depending on where you place it on the path: start, middle, end. However, once the profile stay on the working plane, how is it rotated 2 dimensionally on that plane?
I created a non-symmetric profile and could not find a way to control its rotation on the working plane except try it until it is corrected positioned.
Replies (8)
Message 2 of 9
Corsten.Au
Hi
First of all its better to create a family using " Profile " and insert that " Profile family "
to use further in extrusion, sweep etc..
Then while editing sweep, you may select the profile, and Revit will give further option
for rotating it, and offset etc...
example
Profile 180.JPG.
Profile - Zero.JPG.
Profile - offset.JPG.
Profile - 90.JPG.
Corsten
Building Designer
Message 3 of 9
longt61
This is indeed a good way to control profile position. Still, there are 2 things I wonder if you could explain a little further:
1. You said "edit sweep", does that mean I have to create sweep and commit to data base, then I can edit the profile?
2. In order to edit the position/ rotation of the sweep profile, I have to know how it is original place on working/sweep plane. Unfortunately, I don't, and the api does not offer any kind of visual interaction with the profile like what you have shown in Revit.
Thank you very much.
Message 4 of 9
Corsten.Au
1. I haven't used the api or any tools, am just trying to explain from my general understanding of revit work.
2. usually committing to the sweep and then changing profile does works... in this case, profile should be
a family...
3. if you see the profile family template... there's a method to create profile... now the problem is  there are few
types of profile templates and they can be used within each other.
Have a look at this .. different types of profile..
I try to stick to last one, and use " A " side..
and the Insertion point is the Intersection between X and Y axis..
its better to have a profile drawn only on one quadrant, only then the flipping etc
will work flawlessly,
Overlapping profile between quadrants makes the profile unpredictable....
Green - Profile sketch side..
Red - Host side..
hope that helps a bit...
Best luck..
Corsten
Building Designer
Message 5 of 9
longt61
Thank you for the detailed information. That does help me to understand how Revit work a lot.
Message 6 of 9
agnes.sojka
The answer is wrong. As using profile family for sweep will allows you to control it only where sweep starts/profile is inserted. The profile will rotate anyway around the 3D path.
Message 7 of 9
Ziqq
Yes. You are right.
Message 8 of 9
Corsten.Au
Yes. You are right. @agnes.sojka
just that OPs question was not regarding 3D path, but 2D rotation in a plane.
Cheers.
Corsten
Building Designer
Message 9 of 9
agnes.sojka
##- Is there any solution then for the profile to stop rotating around 3D path ? -##
Pobierz aplikację Outlook dla systemu Android
Agnes Sojka
Surveyor
TEL : 01469 577695
DDI : 01469 565166
MOB : 07525 967037
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to which they are addressed. If you have received this email in error please notify the system manager. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company. Finally, although the company has taken reasonable precautions to ensure no viruses are present in this email, the company cannot accept responsibility for any loss or damage arising from the use of this email or attachments and consequently the recipient should check for the presence of viruses.
