Question About Computer Needed to Run Revit
I need to get Revit for a class I have for college.  I want to know people's views on whether a laptop with this configuration/specs will run the program well or not.  Please let me know as I do not know much about computers!
General Information
Series
Omen
Model Number
3UK57UA#ABA
Lifestyle
Gaming
Color - Lid
Shadow Black
Color - Base
Black
Color - Keyboard
Black
Platform
Notebook PC
Operating System
Operating System
Windows 10 Home
Processor
CPU Brand
Intel
CPU Core
Six-Core
CPU Type
Core i7
CPU Speed
8750H (2.2GHz)
Smart Cache
9MB
FSB
DMI 8GT/s
Turbo Boost Speed
Up to 4.1GHz
CPU Main Features
Hyper-Threading Technology
Virtualization Technology
Intel 64
Enhanced Intel SpeedStep Technology
Idle States
Thermal Monitoring Technologies
Intel Flex Memory Access
Execute Disable Bit
Virtualization Technology for Directed I/O (VT-d)
Turbo Boost Technology 2.0
Intel VT-x with Extended Page Tables (EPT)
Intel Identity Protection Technology
Intel Secure Key
OS Guard
Intel Software Guard Extensions
Intel AES New Instructions
Intel Memory Protection Extensions
Intel Speed Shift Technology
Intel Optane Memory Supported
Memory
Total Memory
16GB
Memory Speed
DDR4-2666
Form Factor
260-pin SO-DIMM
Memory Configuration
1 x 16GB
Hard Drive
HD Capacity
1TB
HD Configuration
1 x 1TB
Solid State Drive
SSD Interface
PCIe NVMe M.2
SSD Capacity
256GB
SSD Configuration
1 x 256GB
Multimedia Drives
Optical Drive
None
Display
Screen Size
15.6"
Display Type
Full HD IPS LED-backlit LCD
Display Finish
Matte
Resolution
1920x1080
Widescreen
Yes
Front Camera
Yes
Front Camera Features
HD
Wide Vision
Video
GPU Type
NVIDIA GeForce GTX 1060
Video Memory
6GB GDDR5
VR Ready
Yes
Audio
Speakers
Dual Speakers
Built-in Microphone
Dual Microphones
Audio System
Bang & Olufsen
Communications
LAN
Gigabit LAN
LAN Data Transfer Rate
10/100/1000Mbps
WLAN
Intel Dual Band Wireless-AC 9560
Wireless Technology
802.11ac
Bluetooth
Bluetooth 5.0
Card Reader
Memory Card Reader
Multi-format Digital Media Card Reader
Ports & Connectors
USB 3.1
3 x USB 3.1 (Gen 1 Type-A)
USB Sleep & Charge
Yes
HDMI
1
Mini DisplayPort
1
LAN RJ-45
1
Audio
1
Security
Physical Device Security
Kensington NanoSaver Security Lock Support
Keyboard & Mouse
Keyboard Features
Backlit Keyboard
Numeric Keypad
Mouse Type
Touchpad
Multi-Touch Gestures
Corsten.Au
Hi
Try to get 1TB SSD storage...the more the better..
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/S...
this is the excerpt from the above link
Revit 2019Performance: Large, complex models
Operating System ¹Microsoft Windows 7 SP1 64-bit:
Enterprise, Ultimate, Professional, or Home Premium
Microsoft Windows 8.1 64-bit:
Enterprise, Pro, or Windows 8.1
Microsoft Windows 10 Anniversary Update 64-bit (version 1607 or higher):
Enterprise, or Pro
CPU TypeMulti-Core Intel Xeon, or i-Series processor or AMD equivalent with SSE2 technology. Highest affordable CPU speed rating recommended.
Autodesk Revit software products will use multiple cores for many tasks, using up to 16 cores for near-photorealistic rendering operations.
Memory16 GB RAM
  • Usually sufficient for a typical editing session for a single model up to approximately 700 MB on disk. This estimate is based on internal testing and customer reports. Individual models will vary in their use of computer resources and performance characteristics.
  • Models created in previous versions of Revit software products may require more available memory for the one-time upgrade process.
Video Display ResolutionsMinimum:
1920 x 1200 with true color
Maximum:
Ultra-High (4k) Definition Monitor
Video AdapterDirectX 11 capable graphics card with Shader Model 5
Disk Space
  • 5 GB free disk space
  • 10,000+ RPM (for Point Cloud interactions) or Solid State Drive
MediaDownload or installation from DVD9 or USB key
Pointing DeviceMS-Mouse or 3Dconnexion compliant device
BrowserMicrosoft Internet Explorer 7.0 (or later)
ConnectivityInternet connection for license registration and prerequisite component download
Return to Top
Revit LT 2019
Enterprise, or Pro
CPU TypeSingle- or Multi-Core Intel Pentium, Xeon, or i-Series processor or AMD equivalent with SSE2 technology. Highest affordable CPU speed rating recommended.
Memory4 GB RAM
  • Usually sufficient for a typical editing session for a single model up to approximately 100 MB on disk. This estimate is based on internal testing and customer reports. Individual models will vary in their use of computer resources and performance characteristics.
  • /3GB RAM switch not recommended where applicable. Revit software and system stability can be affected by memory conflicts with video drivers when the /3GB switch is active.
1280 x 1024 with true color
Maximum:
Video AdapterBasic Graphics:
Display adapter capable of 24-bit color
Advanced Graphics:
Disk Space5 GB free disk space
Corsten
Building Designer
Thanks Ganesh.  But will the software work with the original configuration and just run better with a 1 TB SSD or do you think the 1 TB SSD is critical?  Thanks again!
christian.riley
Autodesk Support
Autodesk Support
@Anonymous -
The original configuration will work great. In reviewing the specifications it also looks like you do have the 1tb SSD selected for the computer. Below indicates that you should have a 256gb drive as a system drive as well as a 1TB drive for storage and programs.
@Anonymous wrote:
Hard Drive HD Capacity 1TB HD Configuration 1 x 1TB Solid State Drive SSD Interface PCIe NVMe M.2 SSD Capacity 256GB SSD Configuration 1 x 256GB
Christian Riley
Technical Support Specialist
christian.riley
Autodesk Support
Autodesk Support
@Anonymous -
Hi there, I just wanted to check in and see if you needed any more assistance on this issue.
Christian Riley
toula3RTYW
Hi everyone, would 512GB be ok for Revit Lt?
HP Spectre x360 - 15-df0002tx
https://support.hp.com/au-en/document/c06177232
