Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Store DLLs in an external database
2 REPLIES 2
laura.paiva
365 Views, 2 Replies
Hi!
At the moment my add-in has all the dlls that it needs in the %appdata% folder.
I was wondering if it is possible to store all dlls, except the one that is called by the manifest, in a database and load them when Revit is opening.
Do you know if it is possible? And if so, it will slow Revit opening?
Thanks in advance!
Labels (3)
2 REPLIES 2
jeremy_tammik
in reply to: laura.paiva
Very little is impossible in computing. However, the Revit API and framework do not provide any built-in support for such a scenario, so you would be on your own implementing it. I assume it would slow down the startup process somewhat, of course. How much would certainly depend on your implementation.
laura.paiva
in reply to: jeremy_tammik
Thank you, @jeremy_tammik !
Forma Design Contest
Rail Community
