Hi!
At the moment my add-in has all the dlls that it needs in the %appdata% folder.
I was wondering if it is possible to store all dlls, except the one that is called by the manifest, in a database and load them when Revit is opening.
Do you know if it is possible? And if so, it will slow Revit opening?
Thanks in advance!
Solved by jeremy_tammik. Go to Solution.
Very little is impossible in computing. However, the Revit API and framework do not provide any built-in support for such a scenario, so you would be on your own implementing it. I assume it would slow down the startup process somewhat, of course. How much would certainly depend on your implementation.
