Split with gap for walls! alternatives
nia98bim
nia98bim
Hey , I want to split wall with gap in point that i add in wall curve but as i see in revit api forum there is no way to do .
that.
  double gap = 30;
  foreach (XYZ point in verPoints)
      PostableCommand.SplitWithGap(activeView, point,gap);
is there any other ways to do that?
thank you.
Moustafa_K
I recall i read a long discussion about this, gladly i found it here .  regarding the gap, and since this feature is not yet implemented through the api, [part of wish list].
If you tried creating a split by gap through the UI, you would find the wall is with defined space apart and locked by a dimension.
have you tried creating the same? may be this below suggested workflow works
  1. make a copy of the wall you need to split
  2. shorted both wall to the split location minding the gap space
  3. create a dimension connecting both end faces
  4. lock the dimension
did not test it, just a thought that might help triggering something. Over all, it will not be exactly as the built in split with gap,  for example I doubt the following:
  1. any hosted elements will be duplicated
  2. even if we removed the duplicates, the copied host will not respect the voids of the inserted families in the original wall.
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
