Create View 3D while Active Direct 3D Context
Moustafa_K
Moustafa_K
I encountered an issue while running the Direct 3D Context Service. When the service is running but not / actively drawing anything, and I either click or create a 3D view  or assembly ortho View  via the API or UI, the view does not zoom to the extent as it normally would when the service is not running. Please refer to this video for a better demonstration.
Has any one faced the same?
Steps to Reproduce:
  1. Register the Direct 3D service: ExternalServices.BuiltInExternalServices.DirectContext3DService
  2. Create a 3D view.
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
ricaun
What do you mean by service is running with no drawing?
A code sample of the service would help.
My guess is that the boundbox of the DirectContext service is to big, the view see that boundbox and zoom out.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Moustafa_K
I am refereeing to IDirectContext3D and there is no any geometry supplied, it doesn't matter. in both cases has geometry or no, it behaves the same !!!
 I also checked the bounding box thing, tried both returns, but  still same behavior
public Outline GetBoundingBox(View dBView)
    return new Outline(XYZ.Zero, new XYZ(5,5,5));
    return new Outline(dBView.CropBox.Min, dBView.CropBox.Max);
The code very simple
Just register a service, and on the UI click on the View 3D
public void DummyService()
    try
        var d3dServer = new D3DServer();
        d3dServer.RegisterServer();
    catch (Exception ex)
public void RegisterServer()
    ExternalService service = ExternalServiceRegistry.GetService(GetServiceId());
    if (service is MultiServerService multiServerService)
        // register the service so Revit calls it when ever needed
        IList<Guid> activeServerIds = multiServerService.GetActiveServerIds();
        if (!activeServerIds.Contains(SourceId))
            service.AddServer(this);
            activeServerIds.Add(SourceId);
            multiServerService.SetActiveServers(activeServerIds);
Moustafa Khalil
ricaun
Looks like the BoundingBox is doing his job.
The BoundingBox still gonna be count inside the view even if the RenderScene is empty.
You could draw a box where the BoundingBox is located to confirm that.
And if you are not drawing anything, you probably should use the CanExecute to disable the IDirectContext3DServer in the view, pretty sure the BoundingBox is not gonna be count inside the view.
Moustafa_K
Initially, while studying the D3DContext service, I understood that using this service has no effect on the document database. Thus, collecting the size of the view does not depend on this service, but rather on the actual visible elements that are part of the document.
Upon a second review of the documentation, I realized I had missed an important detail.
The outline box of the supplied geometry should be returned when implementing the interface, rather than the view crop box size. This ensures that the view box accurately reflects the size of the graphics supplied to the GPU.
To manage this, returning a dummy outline (1,1,1) is not a good solution. Instead, controlling CanExecute will help prevent triggering GetBoundingBox, thereby not affecting the size of the view.
I believe this is a robust approach. Thanks to @ricaun  for the insight.
public bool CanExecute(View dBView)
    return AugmentedObjects.Any();
    return GeometryOutLine ?? new Outline(XYZ.Zero, new XYZ(1, 1, 1));
Moustafa Khalil
ricaun
I usually return null in the GetBoundingBox when don't have a defined Outline for the graphics, works similar like the view.CropBox.
Yes setting the correct Outline for the GetBoundingBox makes the IDirectContext3DServer work so much cleaner.
Cheers! When I started playing with DirectContext3D I had the same issue at the time. 😆
