saving and closing a file without prompting user
i m using revit 2016 api and when i run the command doc.saveandclose() , it prompts me to "do you want to save changes?" , does anyone knows how can i do it without prompting the user, i have opend an adsk file using revit api and also in the active session , i m having different file as i know that revit api cant close the current doc, so i want to save and close the behind adsk file using revit api, help please?
jeremytammik
You could first call Document.Save to ensure it is properly saved, and the close it:
http://www.revitapidocs.com/2018/8dec13b6-71f4-45d2-74e3-b109153721b5.htm
No, much better: just call the Close method with the option to save if needed:
http://www.revitapidocs.com/2018/5948b03d-5537-33d4-6e38-a8f16d5d6779.htm
Please always check  the docs yourself before asking any questions.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
but sir, the file is an imported one adsk model , so when i tried to use the save or close function, the code doesnt work and produces an error, but i can use the saveas method and saveandclose method, they work but once again they prompt user to click yes/no button and then prompt user to press the save button.
sir as much i had studied i find out thhat if a model is created in current session we can use only the saveas and saveclose method and user must have to be prompted, and that is what i want to ask,is there any possible way to do the save for the model imported in the current session without prompting the user.
(apology for grammer mistakes!)
