Get Wall Profile Error(CmdWallProfile.cs)
thannaingoo.api
thannaingoo.api
Dear All,
I got the error when I tested the CmdWallProfile.cs below link.
The error is as follows. Please help me how should be correct.
Thank Advance,
Naing oo
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
jeremytammik
Please submit a complete minimal reproducible case for this, so we know what wall you are dealing with. The issue may be specific to your model. In this case, just a minimal model containing the wall causing the problem may be sufficient. Thank you!
Jeremy Tammik
Developer Technical Services
The Building Coder
thannaingoo.api
Dear Jeremy,
Thanks for your quick response. Kindly find the model and code in the link below.
Naing Oo
https://drive.google.com/open?id=1uY4QMdbvp5mQV0GCBKAJedev_ZISZ4N9
jeremytammik
Thank you for the sample model.
I reproduced your problem, and another one as well, and updated the code to handle them both.
The solution is in The Building Coder samples update and the blog:
http://thebuildingcoder.typepad.com/blog/2018/08/wall-profile-command-update.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
thannaingoo.api
Dear @jeremytammik,
I want to thank you for taking the time out to answer my question. I am sure that you are busy, and I appreciate you taking the time to respond. Thank you again.
Eden Oo
jeremytammik
Thank you for your appreciation. My pleasure entirely. I am very glad it helped.
Jeremy Tammik
The Building Coder
