code conversion from c# to vb.net
foreach( Element e in collector )
    ImportInstance inst = e as ImportInstance;
    if( inst != null )
      // Get the Solid from ImportInstance
      GeometryElement geomElem
        = inst.get_Geometry( opt );
 pleases tell,how can i write these lines in vb.net,i am a beginner in vb.net
jeremytammik
  • Open the Revit macro SharpDevelop IDE
  • Enter the original C# code
  • Click on the menu item 'translate'
  • You can also translate to Python
Here is a more detailed description and other more detailed information:
By the way, I would not recommend starting to learn VB.NET in this day and age:
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
thank you very much sir 🙂
