Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit Viewer
2 REPLIES 2
Tripler123
4088 Views, 2 Replies
Revit Viewer
Good,
I have an idea that must be common among you. I would like to be able to send a revit project to the web, be able to modify the parameters and be able to return that information within revit (Only modify shared parameters)
I have tried to use the Jeremy Examples (vA3C to export) and a web viewer (RVT3js) both very good, but I would like to be able to modify the json to be able to return to revit and moficar the elements.
I would like to know if any of you have an idea of how to read a json in revit and modify the parameters. Or I could offer another way to achieve my objective.
2 REPLIES 2
jeremytammik
in reply to: Tripler123
Glad to hear that you like the vA3C project.
Please also check out RvtMetaProp:
http://thebuildingcoder.typepad.com/blog/2017/09/use-forge-or-spreadsheet-to-create-shared-parameter...
https://github.com/jeremytammik/rvtmetaprop
It does exactly what you are asking for.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Tripler123
in reply to: jeremytammik
Gracias Jeremy por su rápida respuesta,
Forge es increible, pero me gustaria inicar algo que no sea de pago anual. la idea de VA3c es genial, por el momento he podido comprender el codigo y establecer ciertos parametros que deseo exportar. creo que con RvtMetaProp podre sacar grandes ideas. Me gustaria hacer algo como asseble.
Muchas gracias de nuevo jeremy .
Forma Design Contest
Rail Community
