Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit cannot run the external application "Result Explorer"
5 REPLIES 5
fitrananda.24116120
2187 Views, 5 Replies
every time I open Revit 2022, massagge like this post tittle pop up.
Labels (4)
5 REPLIES 5
It looks like results manager isn't installed correctly. If possible, try uninstalling it and then reinstalling it. Alternatively, if you have Revit 2021 installed, you could try copying the folder 'C:\Program Files\Autodesk\Revit 2021\AddIns\ResultsManagerExplorer\Icons' to 'C:\Program Files\Autodesk\Revit 2022\AddIns\ResultsManagerExplorer', as they appear to contain the same icons.
do you mean uninstall, is it revit or the result manager? I currently don't have revit 2021 installed. I only have revit 2018 & 2019
Look at this related but different thread:
https://forums.autodesk.com/t5/revit-api-forum/results-explorer-error-message-in-revit-2022/m-p/1031...
Might your problem have anything to do with that?
Thankyou
I had the same issue with Result Explorer.
When I open the Revit 2022 the same warning pop-up was showing.
I reinstalled the Result Explorer for Revit 2022 from Autodesk website.
And now the issue is resolved.
You can also try the same.
Forma Design Contest
Rail Community
