every time I open Revit 2022, massagge like this post tittle pop up.
Solved by jeremy_tammik. Go to Solution.
It looks like results manager isn't installed correctly. If possible, try uninstalling it and then reinstalling it. Alternatively, if you have Revit 2021 installed, you could try copying the folder 'C:\Program Files\Autodesk\Revit 2021\AddIns\ResultsManagerExplorer\Icons' to 'C:\Program Files\Autodesk\Revit 2022\AddIns\ResultsManagerExplorer', as they appear to contain the same icons.
Look at this related but different thread:
Might your problem have anything to do with that?
I had the same issue with Result Explorer.
When I open the Revit 2022 the same warning pop-up was showing.
I reinstalled the Result Explorer for Revit 2022 from Autodesk website.
And now the issue is resolved.
You can also try the same.
